Kingston 128GB SDXC React Plus Card
Quicklinx: FQBJWS00 Mfr#: MLPR2/128GB
Kingston’s Canvas React Plus SD card delivers high-performance speeds which are designed to work with industry-standard professional cameras for creatives that shoot 4K/8K videos and high-resolution photos. Designed with the latest UHS-II standards and top-of-the-line U3 and V90 speed classes, the Canvas React Plus SD enables you to shoot sequential burst-mode shots with recording speeds of up to 260MB/s1. Execute your creativity without experiencing slow speeds and dropped frames while maximising workflow and efficiency. With transfer speeds of up to 300MB/s, enhance your post-production process and handle heavy workloads with ease while capturing cinematic quality in high resolutions.
Kingston’s Canvas React Plus SD card is the go-to performance SD card for content creators making their way in digital filmmaking and professional photography.
Ultimate speeds to support professional camera use Capture 4K/8K Ultra-HD high-speed shots without dropping frames Top-of-the-line performance for professional content creators Durable
  • Ultimate speeds to support professional camera use
    With superior transfer and recording speeds, this card is ideal for professional creators.
  • UHS-II standard for reliable high-resolution recording
    Capture 4K and 8K Ultra-HD high-speed shots and videos without dropping frames.
  • Excellent performance for professional photographers and digital filmmakers
    The Canvas React Plus leverages UHS Speed Class 3 (U3) and Video Speed Class 90 (V90) for peak performance with professional camcorders and digital cinema cameras.
  • Optimize file transfer with included UHS-II SD reader
    Expedite your workflow with quick transfers using the included MobileLite Plus SD reader.
Kingston Canvas React Plus - flash memory card - 128 GB - SDXC UHS-II
Flash memory card
SDXC UHS-II Memory Card
Storage Capacity
128 GB
Speed Rating
Video Class V90 / UHS-II U3 / Class10
Flash memory card
Storage Capacity
128 GB
Speed Class
Read Rate
Up to 300 MB/s
Write Rate
Up to 260 MB/s
SD card reader (USB)
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
