Kingston’s Canvas React Plus microSD card delivers reliable and durable performance for professional creatives shooting brilliant 4K/8K videos and high-resolution photos without having to worry about dropped frames and slow speeds. Designed with the latest UHS-II standards and top-of- the-line U3 and V90 speed classes, the Canvas React Plus microSD cards are compatible with industry-standard professional HD drones and action cameras. Shoot sequential burst-mode shots with recording speeds of up to 165MB/s and capture videos in Ultra-HD cinematic quality. The Canvas React Plus microSD supports A1 Application Performance Class to expedite your workflow with faster application performance on smartphones and tablets. It comes included with Kingston’s MobileLite Plus microSD reader with transfer speeds of up to 285MB/s for enhanced post-production workflow and efficiency, as well as a microSD adapter.
Ultimate speeds to support professional camera use
With superior transfer and recording speeds, this card is ideal for professional creators. -
UHS-II standard for reliable high-resolution recording
Capture 4K and 8K Ultra HD high-speed shots and videos without dropping frames. -
Supports A1 app performance class
Expedite your workflow with faster application performance. -
Optimize file transfer with included microSD reader
Expedite your workflow with quick transfers using the included MobileLite Plus microSD reader.
- Kingston Canvas React Plus - flash memory card - 128 GB - microSDXC UHS-II
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-II Memory Card
- Storage Capacity
- 128 GB
- Speed Rating
- A1 / Video Class V90 / UHS-II U3 / Class10
- Included Memory Adapter
- microSDXC to SD adapter
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 128 GB
- Speed Class
- Read Rate
- Up to 285 MB/s
- Write Rate
- Up to 165 MB/s
- Form Factor
- Included Accessories
- microSD card reader (USB)
- Limited warranty - lifetime
- 11 mm
- 15 mm
- Thickness
- 1 mm
- -25 °C
- 85 °C
