Kingston 128GB DataTraveler Micro 3.1 USB3.1 Flash Drive
Quicklinx: BYN8WS00 Mfr#: DTMC3/128GB
Small and capless to go anywhere. DataTraveler® Micro 3.1 is an ultra-small, capless, lightweight Flash drive that delivers USB 3.1 Gen 1 (USB 3.0) speeds up to 100MB/s read and 15MB/s write, even with large files such as HD movies and uncompressed audio. It features a metal casing and a built-in key loop. There’s no cap to lose plus it’s small enough to stay plugged into your notebook when you place it in your bag. Store up to 128GB, enough to hold movie and music catalogs, on this plug-and-play Flash drive.
For more information, go to Kingston’s Flash Memory Guide at kingston.com/flashguide.
  • Ultra-small, capless design with metal casing
  • USB 3.1 Gen 1 (USB 3.0) speeds
  • Up to 128GB of expanded storage for tablets, notebooks and more.
  • Ultra-small
    This compact and lightweight drive is easy to take with you and small enough to keep plugged into your notebook even when placed in its bag.
  • Metal casing
    The drive's metal casing complements any compatible device. It's capless, so there's no cap to lose or break.
  • USB 3.1 speeds
    With speeds of up to 100 MB/s, DT Micro 3.1 saves time, even with large files, and is faster than USB 2.0 flash drives.
Kingston DataTraveler Micro 3.1 - USB flash drive - 128 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
128 GB
Linux 2.6.x or later, Microsoft Windows Vista SP2, Microsoft Windows 7 SP1, Google Chrome OS, Windows 8, Windows 8.1, Windows 10, Apple MacOS X 10.8.x or later
5-year warranty
USB flash drive
Storage Capacity
128 GB
Read Rate
Up to 100 MB/s
Write Rate
Up to 15 MB/s
Interface Type
USB 3.1
Metal body
Limited warranty - 5 years
24.95 mm
12.2 mm
4.5 mm
60 °C
