Superior speed, stylish design
Kingston’s DataTraveler® Elite G2 is a stylish Flash drive with enough capacity to transfer films, pictures and work files wherever you go. This drive is compliant with the USB 3.1 Gen 1 (USB 3.0) specification and delivers incredible performance to save time when transferring videos, photos and other large files. The metal casing is shock- and water-resistant so you can be confident when bringing your data with you.
The sleek design of the DataTraveler Elite G2 complements any compatible device and is backwards-compatible with USB 2.0 to allow users to migrate to USB 3.0 in the future. It is backed by a five-year warranty, free technical support and legendary Kingston® reliability.
*USB 3.1 Gen 1 performance requires a host device with a USB 3.0 or 3.1 port.
• Quicker file transfers compared to standard USB 3.1 Gen 1 and USB 2.0 devices
• Shock- and water-resistant metal casing with removable cap
• LED status indicator
- Kingston DataTraveler Elite G2 - USB flash drive - 128 GB
- Product Type
- USB flash drive
- Interface Type
- USB 3.1 Gen 1
- Storage Capacity
- 128 GB
- OS Required
- Linux 2.6 or later, Google Chrome OS, Microsoft Windows 7 / 8 / 8.1 / 10, Apple MacOS X 10.9.x or later
- 5-year warranty
- Product Type
- USB flash drive
- Storage Capacity
- 128 GB
- Read Rate
- Up to 180 MB/s
- Write Rate
- Up to 70 MB/s
- Interface Type
- USB 3.1 Gen 1
- Shockproof, water resistant, metal body
- OS Required
- Limited warranty - 5 years
- 10.8 mm
- 18.98 mm
- 59.37 mm
- 0 °C
- 60 °C
