Kingston 128GB Canvas Select Plus SD Card
Quicklinx: FQ9YWS00 Mfr#: SDS2/128GB
£8.36 ex VAT
£10.03 inc VAT
Kingston's Canvas Select Plus SD card is designed with exceptional performance, speed, and durability for heavy workloads such as transferring and developing high-resolution photos or capturing and editing full HD videos. It can reach Class 10 UHS-I speeds up to 100MB/s for easy storage and quick transfers along with an advanced UHS-I interface that can record cinematic Full HD and 4K Ultra HD videos. The Canvas Select Plus SD card is built to perform in the harshest environments and conditions so you can take it anywhere knowing your files, photos, and videos are protected.
  • Enhanced durability
    Designed to withstand challenging conditions, the Kingston Canvas Select Plus is X-ray proof, shockproof, temperature-proof, vibration-proof, and waterproof. This resilience ensures your data remains safe, whether you're braving the great outdoors or simply going about your daily commute.
  • High-speed performance
    With a read rate of 100 MB/s and a write rate of 85 MB/s, this SDXC UHS-I memory card offers performance suitable for high-resolution photography and 4K video recording. The speed class rating of Video Class V30 / UHS-I U3 / Class10 ensures smooth video capture and playback without interruption.
  • Broad compatibility
    The Kingston Canvas Select Plus flash memory card is designed for compatibility with a wide range of devices. Its compatibility feature means it can be used across various devices, making it a versatile choice for photographers, videographers, and other professionals.
Kingston Canvas Select Plus - flash memory card - 128 GB - SDXC UHS-I
Flash memory card
SDXC UHS-I Memory Card
Storage Capacity
128 GB
Speed Rating
Flash memory card
Storage Capacity
128 GB
Speed Class
Read Rate
Up to 100 MB/s
Write Rate
Up to 85 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
24 mm
32 mm
2.1 mm
-25 °C
85 °C
Type: SDXC UHS-I Memory Card
Capacity: 128GB
SD Speed Class: Video Class V30 / UHS-I U3 / Class10
Brand: Kingston
