Kingston’s Canvas Select Plus microSD is compatible with Android devices and designed with A1 rated performance. It offers improved speed and capacity for loading apps faster and capturing images and videos. Powerful in performance, speed, and durability, the Canvas Select Plus microSD is designed for reliability when shooting and developing high-resolution photos or filming and editing Full HD videos. Kingston Canvas cards are durable in the harshest environments and conditions so you can take them anywhere with confidence that your photos, videos, and files will be protected.
                Faster speedsClass 10 UHS-I speeds up to 100MB/s.
                Optimized for use with Android devicesImproved performance when used with an Android smartphone or tablet.
                Great capacityExcellent capacity to store all your memorable photos and videos.
                DurableFor your peace of mind, the card is waterproof, temperature proof, shock and vibration proof and X-ray proof.
- Kingston Canvas Select Plus - flash memory card - 128 GB - microSDXC UHS-I
- Product Type
- Flash memory card
- Form Factor
- microSDXC UHS-I Memory Card
- Storage Capacity
- 128 GB
- Speed Rating
- A1 / Video Class V10 / UHS Class 1 / Class10
- Included Memory Adapter
- microSDXC to SD adapter
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 128 GB
- Speed Class
- Read Rate
- Up to 100 MB/s
- Form Factor
- Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
- Limited warranty - lifetime
- 11 mm
- 15 mm
- Thickness
- 1 mm
- -25 °C
- 85 °C
