Kingston's UV500 family of solid-state drives dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a Marvell Dean controller combined with 3D NAND Flash for read and write speeds up to 520MB/s and 500MB/s, this SSD is 10X faster than a traditional hard drive for better performance, ultra-responsive multi-tasking and an overall faster system. UV500 provides end-to-end data protection, supports 256-bit AES hardware-based encryption and TCG Opal 2.0 security management solutions. More reliable and durable than a hard drive, UV500 is built with NAND Flash semiconductor memory. There are no moving parts, making it far less likely to fail than a mechanical hard drive. It is also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
- Kingston UV500 - SSD - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- Hardware Encryption
- Encryption Algorithm
- 256-bit AES
- NAND Flash Memory Type
- 3D triple-level cell (TLC)
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- End-to-end data protection, Marvell 88SS1074 controller
- 69.85 mm x 100.1 mm x 7 mm
- 41 g
- 5-year warranty
- Capacity
- 120 GB
- 256-bit AES
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.85 mm
- 100.1 mm
- 7 mm
- 41 g
Performance
- SSD Endurance
- 60 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 520 MBps (read) / 320 MBps (write)
- Maximum 4KB Random Write
- 18000 IOPS
- Maximum 4KB Random Read
- 79000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 0.5 Watt (average) , 0.195 Watt (idle) , 1.17 Watt (read) , 2.32 Watt (write)
- Limited warranty - 5 years , Technical support
- 0 °C
- 70 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 85 °C
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
