High performance. Low price. You game?
HyperX® FURY solid-state drive delivers impressive performance at an affordable price, to get you into the game faster and improve your gameplay. Available in capacities of up to 240GB, it features a slim 7mm form factor and SandForce® SF-2281 controller with SATA Rev 3.0 (6Gb/s) performance for faster system boot up, application loading and file execution plus faster map and level load time. Its synchronous NAND allows for higher and consistent drive performance. So you're not only in the game, you're winning it.
In 120GB and 240GB capacities, HyperX FURY SSD is available as a stand-alone drive and is easy to install. This cost-e cient upgrade is less disruptive than buying a new system to increase performance. The new FURY entry-level product line from HyperX includes memory and SSDs and is designed for gamers, enthusiasts and system Integrators, who can now have consistent HyperX branding for their gaming PCs. Built with Flash memory, HyperX FURY SSD has no moving parts and is cooler, quieter and more shock- and vibration-resistant than traditional hard drives, making it the ideal hard drive replacement. It's backed by a three-year warranty and free technical support.
- SandForce controller with SATA Rev 3.0 (6Gb/s) performance
- Read/write speeds of 500/500 MB/s
- Features synchronous NAND for consistent high SSD performance
HyperX FURY SSD is ideal for
- Faster system boot up times, application loading & file execution
- Faster map and level load times in game with increased frames per second
- Fast -- boosts overall system responsiveness and performance
- Improved gameplay -- dramatically reduces game and level loading times to get into the game faster
- Slim -- 2.5-inch drive available in 7mm to fi t in more systems (even slimmer notebooks)
- Reliable -- cool, rugged and durable drive to push your system to the limits
- Cost-eflffective -- oflffers the perfect combination of price/performance for budget-minded users
- Form factor 2.5"
- Interface SATA Rev. 3.0 (6Gb/s) with backwards compatibility to SATA Rev. 2.0
- Capacities1 120GB, 240GB
- Baseline performance2 Compressible data transfer (ATTO)
- All capacities: 500MB/s read and 500MB/s write
- Incompressible data transfer (AS-SSD and CrystalDiskMark)
- 120GB -- 420MB/s read and 120MB/s write
- 240GB -- 470MB/s read and 220MB/s write
- Maximum 4k Read/Write
- 120GB -- up to 84,500/ up to 52,000 IOPS
- 240GB -- up to 84,500/ up to 41,000 IOPS
- Random 4k Read/Write
- 120GB -- up to 11,500/ up to 52,000 IOPS
- 240GB -- up to 22,500/ up to 41,000 IOPS
- PCMark® Vantage HDD Suite Score
- 120GB -- 60,000
- 240GB -- 60,000
- PCMark 8 storage bandwidth
- 120GB - 140 MB/s
- 240GB - 180 MB/s
- Total Bytes Written (TBW)3 120GB: 354TB 2.75 DWPD4
- 240GB: 641TB 2.5 DWPD4
- Power consumption: 0.31 W idle / 0.35 W avg / 1.65 W (MAX) read / 2.76 W (MAX) write
- Storage temperature -40°C~85°C
- Operating temperature 0°C~70°C
- Dimensions 69.8mm x 100.1mm x 7mm
- Weight 90.03g
- Vibration operating 2.17G peak (7-800Hz)
- Vibration non-operating 20G peak (10-2000Hz)
- Life expectancy 1 million hours MTBF
- Warranty/support three-year warranty with free technical support
- HyperX FURY - solid state drive - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Synchronous flash memory, SandForce SF-2281 controller
- 69.8 mm x 100.1 mm x 7 mm
- 90.03 g
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.8 mm
- 100.1 mm
- 7 mm
- 90.03 g
Performance
- Drive Writes Per Day (DWPD)
- 2.75
- SSD Endurance
- 354 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 500 MBps (read) / 500 MBps (write)
- 4KB Random Read
- 11500 IOPS
- 4KB Random Write
- 52000 IOPS
- Maximum 4KB Random Write
- 52000 IOPS
- Maximum 4KB Random Read
- 84000 IOPS
Reliability
- MTBF
- 1,000,000 hour(s)
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 1.65 Watt (read) , 2.76 Watt (write) , 0.31 Watt (idle) , 0.35 Watt (average)
- ISO 9001:2008, SGS
- Limited warranty - 3 years
- 0 °C
- 70 °C
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
