Kingston 1.6TB DC400 2.5" SATA 6Gb/s SSD
Quicklinx: CBZYWS00 Mfr#: SEDC400S37/1600G
DC400 SSD
Kingston’s DC400 SSD offers consistent application performance and low latency over a wide range of read/write workloads, and standard as well as user-adjustable over-provisioning to improve random IOPs performance, making it ideal for data centres. Its enterprise firmware improves latency and helps DC400 deliver consistently low data access times under steady state workloads. It’s available in a Performance-Optimised model with greater IOPs for faster application performance and reduced storage latency and in a Read-Intensive Optimised model.
Consistently high sustained IOPs and low latency
Configurable over-provisioning available
Performance-Optimised model and Read-Intensive model available by special order
Enterprise-class reliability
Legendary Kingston support
  • Enhanced durability
    With an MTBF of 2,000,000 hours and SSD Endurance of 1678 TB, the Kingston SSDNow DC400 is built to withstand extensive use, ensuring reliability and longevity.
  • Optimized performance
    Experience speed with up to 555 MBps internal data rate and 100000 IOPS maximum 4KB random read, making it ideal for demanding applications and multitasking.
  • Energy efficient
    Designed with power efficiency in mind, the DC400 operates on an average of 1.6 watts, with specific modes to reduce power consumption further during idle, read, and write operations.
  • Advanced features
    Equipped with Dynamic and Static Wear Leveling, Firmware-based Power-Loss Protection, and SmartECC, the DC400 offers enhanced data integrity and protection against unexpected power outages.
Kingston SSDNow DC400 - SSD - 1.6 TB - SATA 6Gb/s
Solid state drive - internal
1.6 TB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Dynamic and Static Wear Leveling, Hot-Plug Support, SmartRefresh, Firmware-based Power-Loss Protection, SmartECC, S.M.A.R.T.
69.9 mm x 100 mm x 7 mm
92.34 g
5-year warranty
1.6 TB
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
92.34 g
Performance
Drive Writes Per Day (DWPD)
0.57
SSD Endurance
1678 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
555 MBps (read) / 510 MBps (write)
4KB Random Read
78000 IOPS
4KB Random Write
32000 IOPS
Maximum 4KB Random Write
88000 IOPS
Maximum 4KB Random Read
100000 IOPS
Reliability
MTBF
2,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
1.6 watt (average) , 1.56 watt (idle) , 1.8 watt (read) , 4.86 watt (write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
