The microSDHC cards offer higher storage capacities for more music, more videos, more pictures, more games - more of everything you need in today's mobile world. The microSDHC card allows you to maximize today's revolutionary mobile devices. Kingston's microSDHC cards use the speed "class" rating that guarantee a minimum data transfer rate for optimum performance with devices that use microSDHC.
Identical in physical size to today's standard microSD card, the microSDHC cards are designed to comply with SD specification version 2.00 and are only recognized by microSDHC host devices. They can be used as full-size SDHC cards when used with the included adapter.
- Kingston - flash memory card - 4 GB - microSDHC
- Product Type
- Flash memory card
- Form Factor
- microSDHC
- Storage Capacity
- 4 GB
- Speed Rating
- Class 10
- Included Memory Adapter
- microSDHC to SD adapter
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 4 GB
- Speed Class
- Class 10
- Form Factor
- microSDHC
- Limited warranty - lifetime
- 11 mm
- 15 mm
- Thickness
- 1 mm
- 1.4 g
- -25 °C
- 85 °C
