Kingston - Flash memory card ( microSDHC to SD adapter included ) - 16 GB - Class 10 - microSDHC
Quicklinx: 7054WS00 Mfr#: SDC10/16GB
The microSDHC cards offer higher storage capacities for more music, more videos, more pictures, more games - more of everything you need in today's mobile world. The microSDHC card allows you to maximize today's revolutionary mobile devices. Kingston's microSDHC cards use the speed "class" rating that guarantee a minimum data transfer rate for optimum performance with devices that use microSDHC.
Identical in physical size to today's standard microSD card, the microSDHC cards are designed to comply with SD specification version 2.00 and are only recognized by microSDHC host devices. They can be used as full-size SDHC cards when used with the included adapter.
  • Compliant
    With the SD specification version 2.00.
  • Versatile
    When combined with the adapter, can be used as a full-size SDHC card.
  • Compatible
    With microSDHC host devices; not compatible with standard microSD-enabled device/readers.
  • File format
    FAT 32.
Kingston - flash memory card - 16 GB - microSDHC
Flash memory card
microSDHC
Storage Capacity
16 GB
Speed Rating
Class 10
Included Memory Adapter
Flash memory card
Storage Capacity
16 GB
Speed Class
Class 10
microSDHC
Limited warranty - lifetime
11 mm
15 mm
Thickness
1 mm
1.4 g
-25 °C
85 °C
