Get more out of your mobile world
Kingston's microSDHC Class 10 card offers higher storage capacity and performance that meets the Class 10 Standard. Kingston's 32 GB microSDHC card uses the speed "class" rating that guarantee a minimum data transfer rate for optimum performance with devices that use microSDHC.
As someone who jumped on the latest, highly advanced phone, tablet or camera, you're probably not a big fan of waiting around. And who can blame you -- life is short and you've got better things to do than wait around for your pictures, movies or music to transfer to your PC. That's why Kingston® offers the Class 10 microSDHC card, featuring the fastest speeds available in a microSD card and 32GB capacity. Now you can quickly and easily transfer large photographs, games, videos, music collections and other files to other devices, a PC or the Internet -- without the long wait
Highlights
Class 10 -- 10MB/s minimum data transfer rate
Compliant -- with the SD card Specification Standards
Versatile -- when combined with an SD adapter, can be used as a full-size SDHC card
Compatible -- with microSDHC and microSDXC host devices
File Format -- FAT 32
Guaranteed -- lifetime warranty, free technical support
- Kingston - flash memory card - 32 GB - microSDHC
- Product Type
- Flash memory card
- Form Factor
- microSDHC
- Storage Capacity
- 32 GB
- Speed Rating
- Class 10
- Limited lifetime warranty
- Product Type
- Flash memory card
- Storage Capacity
- 32 GB
- Speed Class
- Class 10
- Form Factor
- microSDHC
- Limited warranty - lifetime
- 11 mm
- 15 mm
- Thickness
- 1 mm
- 2.7 g
- -25 °C
- 85 °C
