The thumb keypad includes often used keys such as Enter, Space, Backspace, Delete and the combination keys, Control and Alt on the PC. This redistributes the workload from your relatively weaker and overused little fingers to stronger thumbs.
This separation minimizes strain and stretching by positioning your arms approximately at shoulder width and with wrists straight. This design reduces abduction and ulnar deviation (common symptoms experienced with repetitive strain injuries such as carpal tunnel syndrome and tendonitis).
Separate thumb keypads
The thumb keypad includes often used keys such as Enter, Space, Backspace, Delete and the combination keys, Control and Alt on the PC. This redistributes the workload from your relatively weaker and overused little fingers to stronger thumbs. -
Separate key wells for each hand
- Kinesis Advantage Pro - keyboard - US - metallic
- Keyboard - ergonomic (contoured)
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- US
- Hot Keys Function
- Macros buttons
- 2-port USB hub, MPC technology
- Metallic
- 41.9 cm x 20.3 cm x 7.6 cm
- Interface
- USB
Input Device
- Hot Keys Function
- Macros buttons
- US
- 41.9 cm
- 20.3 cm
- 7.6 cm
- 2 x USB
- Metallic
- Included Accessories
- Palm Pads
