Supports up to 4 monitors in 1080p, perfect for multi-screen computing Easy-to-use, Plug and Play
- No change required on source device (GPU/display driver)
- Easily works with all Display-Port enabled PCs - both notebooks and desktops
- Interoperability/standards support
- Backward compatible with future DP 1.2
- No need for WHQ
- Powered by IDT ViewXpand VMM1402
- 2x2 display stacking
- 4x1, 3x1, 2x1 line-up
- Compatible with Display Port v1.1a, HDMI 1.3, HDCP v1.3
- No need for WHQL
- Supports digital audio stream on Display Port input and HDMI out
- PCI Express or PCI Express 2.0-compliant motherboard with one dual-width x16 graphics slot
- Minimum 300W or greater system power supply (with a minimum 12V current rating of 18A
Package Contents
- User Manual
- Driver Disk
- DMS59 to dual DVI converter x2
- NVIDIA unified architecture
- NVIDIA CUDA technology
- Direct compute support
- OpenCL support
- NVIDIA PureVideo HD technology
- High definition 1080p display support
- NVIDIA PhysX technology
- Dual-link DVI, VGA and HDMI output
- Dual-link HDCP capable
- PCI Express 2.0 support
NVIDIA GeForce Graphics
Graphics processing has become an essential ingredient to the modern PC. Nowadays, we simply demand more from our PCs. If you want to enhance photos, edit videos, watch movies, play games, or if you simply desire a Premium Windows® 7 Experience, NVIDIA® GeForce® graphics brings impressive graphics processing power to your PC at an incredible value.
Spectacular Video
Get all the video processing power that your digital lifestyle requires. Enhance photos, clean up home videos and post them to Facebook up to 50% faster² with the GeForce 210 or GeForce GT520 GPUs. Convert your video and put it on your iPod in minutes instead of hours³ or make your DVDs look like HD. Does your PC have a CPU powerful enough to playback high definition Blu-Ray Movies? It doesn’t matter, the GeForce 210 and GT520 can playback any Blu Ray Movie with any modern CPU4.
Gorgeous Graphics
Modern games and 3D applications demand more graphics performance than ever before and Intel integrated graphics simply aren’t good enough. The GeForce 210 delivers over 10x the performance¹ of Intel integrated solutions! If you want to play popular mainstream games like World of Warcraft, Spore or Sims3, the GeForce 210 is an essential addition to your PC. For games that require more performance or DirectX 11 then the GT520 is the ideal graphics processor to get you and your system to the next level.
Premium Windows 7 Experience
Graphics processing units (GPUs) are an essential element of today’s PCs, enabling more visual and more interactive experiences. As a leader in visual computing and the inventor of the GeForce GPU, NVIDIA worked closely with Microsoft on the development of Windows 7 to ensure that its GPUs take full advantage of the great new features and functionality. If you use your PC to enhance photos, watch or edit videos, play games, or if you simply desire a fast and efficient graphical interface, NVIDIA GPUs will surely delight your senses and offer a premium Windows 7 experience.1 Compared to Intel G45. Measured using 3DMark Vantage, Performance Pre-set on a Pentium Dual Core E5200 system with 2GB RAM, Vista SP1.
See NVIDIA GeForce Graphics Cards In Action
2 Compared to E8200 CPU with no GPU. Measured using MotionDSP vReveal on G31 system with 2GB RAM, Vista SP1. 3Comparison made using 30min 720p video clip on a Core2 Duo E8200, G31 system with 2GB RAM, Vista SP1. CPU test run on Apple iTunes. GPU test run on Elemental Technologies Badaboom. 4 Intel Atom CPU or better
Spectacular video
Get all the video processing power that your digital lifestyle requires. Enhance photos, clean up home videos and post them up to 50% faster with the GeForce 210. Convert your video and put it on your iPod in minutes instead of hours or make your DVDs look like HD. Does your PC have a CPU powerful enough to playback high definition Blu-ray movies? It doesn't matter, the GeForce 210 can playback any Blu-ray movie with any modern CPU. -
Gorgeous graphics
Modern games and 3D applications demand more graphics performance than ever before and Intel integrated graphics simply aren't good enough. With 16 processing cores, the GeForce 210 delivers over 10x the performance of Intel integrated solutions! -
Fully unified graphics core dynamically allocates work to geometry, vertex, physics, or pixel shading operations, delivering superior graphics processing power. -
NVIDIA CUDA parallel computing architecture
CUDA technology unlocks the power of the GPU's processor cores to accelerate the most demanding system tasks - such as video transcoding - delivering incredible performance improvements over traditional CPUs. -
DirectCompute support
Full support for DirectCompute, Microsoft's GPU computing API. -
OpenCL support
Full support for OpenCL GPU computing API. -
NVIDIA GeForce Unified Driver Architecture (UDA)
Delivers a proven record of compatibility, reliability, and stability with the widest range of games and applications. GeForce drivers provide the best out-of-box experience for every user and deliver continuous performance and feature updates over the life of GeForce GPUs. -
GigaThread technology
Massively multi-threaded architecture supports thousands of independent, simultaneous threads, providing extreme processing efficiency in advanced, next generation shader programs. -
NVIDIA Lumenex engine
Delivers stunning image quality and floating point accuracy at ultra-fast frame rates. -
16x Anti-aliasing technology
Lightning fast, high-quality anti-aliasing at up to 16x sample rates obliterates jagged edges. -
128-bit floating point High Dynamic-Range (HDR) lighting
Twice the precision of prior generations for incredibly realistic lighting effects - now with support for anti-aliasing. -
The combination of high-definition video decode acceleration and post-processing that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for movies and video. -
Hardware decode acceleration
Provides ultra-smooth playback of H. 264, VC-1, WMV, DivX, MPEG-2 and MPEG-4 HD and SD movies without the need for a dual or quad-core CPU. -
Dual-stream hardware acceleration
Supports picture-in-picture content for the ultimate interactive Blu-ray and HD DVD movie experience. -
Dynamic contrast enhancement and color stretch
Provides post-processing and optimization of High Definition movies on a scene by scene basis for spectacular picture clarity. -
Enhanced error resilience
Correct errors or losses in broadcast content to ensure crisp, high quality playback. -
Advanced spatial-temporal de-interlacing
Sharpens HD and standard definition interlaced content on progressive displays, delivering a crisp, clear picture that rivals high-end home-theater systems. -
High-quality scaling
Enlarges lower resolution movies and videos to HDTV resolutions, while maintaining a clear, clean image. Also provides downscaling of videos, including high-definition, while preserving image detail. -
Bad edit correction
When videos are edited, the edits can disrupt the normal 3:2 or 2:2 pulldown cadence. PureVideo uses advanced processing techniques to detect poor edits, recover the original content, and display perfect picture detail frame after frame for smooth, natural looking video. -
Noise reduction
Improves movie image quality by removing unwanted artifacts. -
Edge enhancement
Sharpens movie images by providing higher contrast around lines and objects. -
Designed to meet the output protection management (HDCP) and security specifications of the Blu-ray Disc format, allowing the playback of encrypted movie content on PCs when connected to HDCP-compliant displays. -
Dual-link DVI support
Able to drive industry's large and high resolution flat-panel displays up to 2560 x 1600 and with support for High-bandwidth Digital Content Protection (HDCP). -
HDMI support
Fully integrated support for HDMI including xvYCC, deep color and 7.1 digital surround sound. -
Designed for the PCI Express 2.0 bus architecture offering the highest data transfer speeds for the most bandwidth-hungry games and 3D applications, while maintaining backwards compatibility with existing PCI Express motherboards for the broadest support. -
Full Microsoft DirectX 10.1 support
DirectX 10.1 GPU with full Shader Model 4.1 support delivers unparalleled levels of graphics realism and film-quality effects. -
OpenGL 3.1 optimization and support
Provides top-notch compatibility and performance for OpenGL applications.
- KFA2 MDT X4 - GeForce 210 - graphics card - GF 210 - 1 GB
- Graphics card
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA GeForce 210
- Memory
- 1 GB DDR2
- Core Clock
- 589 MHz
- CUDA Cores
- 16
- Effective Memory Clock
- 800 MHz
- Shader Clock
- 1402 MHz
- Memory Interface
- 64-bit
- Max Monitors Supported
- 4
- 2 x DVI-I (DMS-59) , 4 x DVI-I (Single-Link) - with adapter
- API Supported
- DirectX 10.1
- Fanless
- 3.8 cm x 14.5 cm x 11.1 cm
- Graphics card - fanless
- Bus Type
- Graphics Engine
- Core Clock
- 589 MHz
- CUDA Cores
- 16
- Shader Clock
- 1402 MHz
- 4
- API Supported
- DirectX 10.1
- Nvidia CUDA technology, Nvidia PureVideo HD technology, dual slot heatsink
- Size
- 1 GB
- Technology
- DDR2 SDRAM
- Effective Clock Speed
- 800 MHz
- Bus Width
- 64-bit
- Required Power Supply
- 300 W
- Additional Requirements
- Dual-width x16 graphics slot
- Cables Included
- 2 x DMS-59 to 2 x DVI adapter
- Software Included
- Drivers & Utilities
- Plug and Play
- 3.8 cm
- 14.5 cm
- 11.1 cm
- 1 kg
