KeySonic Compact Gaming Keyboard With Blue Illuminated Backlight
Quicklinx: 70FSWS00 Mfr#: KSK-6001UELX
The perfect compact keyboard for both, home and office users, including for gamers. Due to the special high-quality key stroke with noticeable pressure point and the very comfortable and quiet typing feeling the keyboard can be used fatigue-proof for a long time. It is ideal for gamers by 20 anti-ghosting keys, which can speed up the complex game actions. In addition, all buttons are really extensively programmable; individual keys or complicated sequences can be programmed to perform multiple actions/commands with a single key stroke. These functions can be saved in various profiles and levels for quick access to a customized and optimized key assignment for every application and every game. The KSK-6001 UELX is equipped with a switch able blue backlight.
KeySonic KSK-6001 UELX - keyboard Input Device
Keyboard
USB
Wired
Keys Qty
104
Blue LEDs, tilt legs, illuminated keys
39.3 cm x 15.8 cm x 2.4 cm
0.64 kg
Package Type
Retail
Keyboard
USB
Keys Qty
104
Keyboard Technology
Membrane
Anti-ghosting
39.3 cm
15.8 cm
2.4 cm
0.64 kg
1 x USB cable - 1.5 m
Plug and Play
Package Type
Retail
Microsoft Windows 98SE/2000/ME/XP, Microsoft Windows 7, Microsoft Windows Vista
50 °C
10 - 95%
