Kensington Wireless ValuMouse
Quicklinx: BZ8DWS00 Mfr#: K72392EU
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: Mac, PC
More than 50 In Stock
£20.81 ex VAT
£24.97 inc VAT
The ideal mouse when you need uninterrupted concentration while working or if you're in a quiet location, such as a library, and don't want to disturb others around you.
Using a compact nano receiver, provides the ultimate freedom and mobility for your mouse with a completely reliable wireless connection so you can always be productive.
The high-definition optical sensor tracks the mouse's movements with smooth accuracy for optimal performance and productivity.
  • Silent click
  • 2.4 GHz wireless connection
  • 1000 DPI sensor
  • Ambidextrous design
    The three button with scroll wheel setup gives both right-handed and left-handed users the freedom to get the most out of the mouse with contours that allows for pain-free and comfortable extended usage.
  • Plug-and-Play installation
    Simply insert the wireless USB receiver into your device and you'll be up and scrolling quickly as the mouse driver will download and install automatically.
Kensington Wireless ValuMouse - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
6 cm x 10.8 cm x 3.8 cm
100 g
Europe
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, ambidextrous design, wireless receiver slot
Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10, Google Chrome OS 44 or later
5-year warranty
Mouse
Wireless Receiver
Orientation
6 cm
10.8 cm
3.8 cm
100 g
Europe
Input Device
Wireless
2.4 GHz
Optical
Buttons Qty
3
Movement Resolution
1000 dpi
1 x USB - 4 pin USB Type A
Plug and Play
Limited warranty - 5 years
Type: Mouse
Colour: Black
Compatibility: Mac
Compatibility: PC
Brand: Kensington
