The ideal mouse when you need uninterrupted concentration while working or if you're in a quiet location, such as a library, and don't want to disturb others around you.
Using a compact nano receiver, provides the ultimate freedom and mobility for your mouse with a completely reliable wireless connection so you can always be productive.
The high-definition optical sensor tracks the mouse's movements with smooth accuracy for optimal performance and productivity.
Silent click
The ideal mouse when you need uninterrupted concentration while working or if you're in a quiet location, such as a library, and don't want to disturb others around you. -
2.4 GHz wireless connection
Using a compact nano receiver, provides the ultimate freedom and mobility for your mouse with a completely reliable wireless connection so you can always be productive. -
1000 DPI sensor
The high-definition optical sensor tracks the mouse's movements with smooth accuracy for optimal performance and productivity. -
Ambidextrous design
The three button with scroll wheel setup gives both right-handed and left-handed users the freedom to get the most out of the mouse with contours that allows for pain-free and comfortable extended usage. -
Plug-and-Play installation
Simply insert the wireless USB receiver into your device and you'll be up and scrolling quickly as the mouse driver will download and install automatically.
- Kensington Wireless ValuMouse - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right and left-handed
- 6 cm x 10.8 cm x 3.8 cm
- 100 g
- Localisation
- Europe
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, battery indicator, on/off power switch, Nano wireless receiver, ambidextrous design, wireless receiver slot
- OS Required
- Apple MacOS X, Microsoft Windows 7 / 8 / 8.1 / 10, Google Chrome OS 44 or later
- 5-year warranty
- Mouse
- Wireless Receiver
- Orientation
- 6 cm
- 10.8 cm
- 3.8 cm
- 100 g
- Black
- Localisation
- Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Optical
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Plug and Play
- OS Required
- Limited warranty - 5 years
