Kensington Wireless Presenter with Green Laser
Quicklinx: C3PNWS00 Mfr#: K72426EU
£56.04 ex VAT
£67.24 inc VAT
Own what professionals use to take control of the room and a laptops cursor with the Expert Wireless Presenter with Green Laser Pointer & Cursor Control. Sometimes pointing just isnt enough. With a simple flick of a switch, you toggle between presentation and cursor control modes. The wireless 2.4GHz receiver stores conveniently inside the remote, and since its uniquely paired, you dont have to worry about device interference. Make your point with a green laser thats 10 times brighter than standard red lasers, ideal for bigger rooms and LED/LCD screens.
  • Effortless control
    The Kensington Presenter Expert is designed with backlit buttons and a built-in laser pointer, ensuring seamless presentations even in fully lit or dark environments.
  • Extended reach
    With a maximum operating distance of 50 m, this presentation remote control offers the freedom to move around large rooms, engaging with the audience without being tethered to a device.
  • Reliable performance
    Equipped with a low battery alert and an easy power on/off feature, the Kensington Presenter Expert ensures your presentations go smoothly without unexpected interruptions.
Kensington Presenter Expert Green Laser with Cursor Control presentation remote control - black
Presentation remote control
Enclosure Colour
Europe
Radio
Max Operating Distance
50 m
Pointing device battery
Enclosure Colour
Europe
Radio
50 m
Low battery alert, built-in laser pointer, back-lit buttons, power on/off
Operating System
Apple Mac OS, MS Windows 7, Windows 8
Carrying pouch
Brand: Kensington
