The wired ValuMouse features a three-button/scroll wheel setup that offers silent clicking when you need to get work done and don't want to disturb anyone in a quiet environment. A high-definition optical sensor provides reliable and responsive control when you're navigating and the comfortable, contoured shaping feels great for either right-handed or left-handed users. It offers Plug & Play installation with a standard USB wired connection.
Silent click
Significantly quieter than a standard mouse, it's ideal if you are using the device in a quiet environment, such as a library or at a conference presentation, and don't want to disturb others around you or interrupt your concentration -
1000 DPI sensor
The high-definition optical sensor tracks the mouse's movements with smooth accuracy for optimal performance and productivity. -
Ambidextrous design
The three buttons with scroll wheel setup gives both right-handed and left-handed users the freedom to get the most out of the mouse with contours that allows for pain-free and comfortable extended usage. -
Simply insert the standard USB wired connector into your device and you'll be up and scrolling quickly as the mouse driver will download and install automatically.
- Kensington ValuMouse - mouse - USB - black
- Mouse
- Connectivity Technology
- Wired - USB
- Black
- Orientation
- Right and left-handed
- 6 cm x 10.8 cm x 3.8 cm
- 90 g
- Movement Detection Technology
- Optical
- Buttons Qty
- 3
- Movement Resolution
- 1000 dpi
- Scrolling wheel, ambidextrous design
- OS Required
- Apple MacOS X 10.5 - 10.8, Microsoft Windows 7 / 8 / 8.1 / 10
- 5-year warranty
- Mouse
- Orientation
- 6 cm
- 10.8 cm
- 3.8 cm
- 90 g
- Black
Input Device
- Wired
- Interface
- USB
- Optical
- Buttons Qty
- 3
- 1000 dpi
- 1 x USB - 4 pin USB Type A
- Plug and Play
- OS Required
- Limited warranty - 5 years
