The Kensington Wall Laptop Power Adapter with USB Power Port is ideal whether you're looking for a replacement or a secondary power adapter for at home or on the move. It provides the reliability that you need and is compatible with a wide range of laptops.
- Kensington Wall Laptop Power Adapter with USB Power Port - power adapter
- Power adapter - external
- Localisation
- Europe
- Output connectors
- 1 x 4 pin USB Type A
- Environmental Standards
- ENERGY STAR
- Localisation
- Europe
- Power Output Connectors Details
- ENERGY STAR
