When you need to put whats on your laptop screen on a monitor or a projector, theres no easier way than with the VM1000 Video Adapter. It plugs into Mini DisplayPort commonly found on laptops and then runs to the VGA port on a monitor or projector. The adapter supports full HD resolution so you get a crystal clear picture and offers Plug & Play installation so youre up and running in no time.
Seamless compatibility
Designed to bridge the gap between your devices, this adapter offers comprehensive compatibility with both Mac and PC. It ensures a smooth connection without the need for additional drivers, thanks to its Plug-and-Play compliance. -
High-quality video output
Experience crisp, clear video quality with support for resolutions up to 1920 x 1200. Whether it's presentations, movies, or any visual content, the adapter ensures your media looks its best on any VGA-equipped display.
- Kensington VM1000 Mini DisplayPort to VGA Adapter - video converter - black
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort input - Mini DisplayPort
- 2.5 cm x 1.3 cm x 27.9 cm
- Enclosure Colour
- Black
- 2-year warranty
- Video converter
- Max Resolution
- 1920 x 1200
- 1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DisplayPort input - Mini DisplayPort - male
- OS Required
- Apple MacOS X 10.6, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11
- Plug and Play
- 2.5 cm
- 1.3 cm
- 27.9 cm
- Enclosure Colour
- Black
- Limited warranty - 2 years
