Kensington Virtuoso Stylus for Tablets - Black
Quicklinx: CRL2WS00 Mfr#: K97031WW
Tablets are great fun to useuntil you realise that every time you touch one to navigate or type, youre just adding another smudge to the tablet screen. The fact is, no matter how clean your hands are they naturally emit oils. And oils and tablet screens dont get along. Before you know it, your screen is covered with grease and oils that not only make it difficult to see the screen but also attract dirt and grime that can permanently scratch and damage your tablet screen.
Fortunately theres a simple solution that not only keeps your screen clean, but also adds accuracy and comfort. Its the Kensington Stylus. The responsive and sensitive soft tip was specially designed to work on delicate tablet screens and smartphones. It glides more smoothly across your tablet screen than any finger and provides comfort and control whether youre creating art, annotating files or just replying to an email. The soft tip will never scratch your tablet screen. And most important it keeps your fingers off the screen so your screen stays nice and clean.
The Virtuoso is available in a rainbow of colors that not only look great on their own, but also mix and match perfectly with the Kensington KeyFolio Exact and Comercio Folios. So go ahead and get the one accessory that will not only preserve your screen but also make using your tablet more comfortable: a Kensington Stylus.
Kensington Virtuoso - stylus
Stylus
Stylus
Pen-like pocket clip
