Kensington VeriMark Guard USB-C Fingerprint Key
Quicklinx: G8QDWS00 Mfr#: K64709WW
Device Type: Laptop
Type: Fingerprint reader
Device Screen Size: [N/A]
Colour: Black, Silver
29 In Stock
£49.04 ex VAT
£58.84 inc VAT
The VeriMark Guard USB-C Fingerprint Key offers the latest in biometric authentication. FIDO2 and FIDO U2F certified with expanded authentication options, including strong single-factor (passwordless), dual, multi-factor and Tap-and-Go for FIDO U2F services. Maximum compatibility with web services including Google, Facebook and Microsoft (for Windows Hello, refer to VeriMark or VeriMark IT), with support for Chrome, Edge, Firefox and Safari. Exceeds industry standards for false acceptance rate (FAR) and false rejection rate (FRR). Supports GDPR compliance.
  • Enhanced security
    The Kensington VeriMark Guard USB-C Fingerprint Key uses advanced fingerprint technology to provide a secure and convenient way to protect your digital life. With its FIDO2 and WebAuthn/CTAP2 compliance, it offers a robust solution for password-free and two-factor authentication, ensuring that your data remains inaccessible to unauthorized users
  • Universal compatibility
    Designed to work across various platforms, the Kensington VeriMark Guard USB-C Fingerprint Key offers seamless integration with a wide range of devices. Its USB-C interface ensures easy connectivity with modern laptops, desktops, and mobile devices, making it a versatile tool for personal and professional use
  • User-friendly design
    Featuring an external form factor, this fingerprint reader is not only portable but also extremely easy to use. Its Plug-and-Play functionality means you can enjoy enhanced security without the need for complex installations or configurations
Kensington VeriMark Guard USB-C Fingerprint Key - FIDO2, WebAuthn/CTAP2, & FIDO U2F - Cross Platform fingerprint reader - USB-C - TAA Compliant
Fingerprint reader
Interface Type
USB-C
TAA Compliant
Fingerprint reader
Interface Type
USB-C
1 x USB - 24 pin USB-C
U2F Certified
TAA Compliant
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: G8QD 050804
Condition: Customer return - item has been opened but is in excellent condition
This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £12.84
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Device Type: Laptop
Colour: Black
Colour: Silver
Brand: Kensington
Stock Status: Used Stock
