The VeriMark Guard USB-C Fingerprint Key offers the latest in biometric authentication. FIDO2 and FIDO U2F certified with expanded authentication options, including strong single-factor (passwordless), dual, multi-factor and Tap-and-Go for FIDO U2F services. Maximum compatibility with web services including Google, Facebook and Microsoft (for Windows Hello, refer to VeriMark or VeriMark IT), with support for Chrome, Edge, Firefox and Safari. Exceeds industry standards for false acceptance rate (FAR) and false rejection rate (FRR). Supports GDPR compliance.
Enhanced security
The Kensington VeriMark Guard USB-C Fingerprint Key uses advanced fingerprint technology to provide a secure and convenient way to protect your digital life. With its FIDO2 and WebAuthn/CTAP2 compliance, it offers a robust solution for password-free and two-factor authentication, ensuring that your data remains inaccessible to unauthorized users -
Universal compatibility
Designed to work across various platforms, the Kensington VeriMark Guard USB-C Fingerprint Key offers seamless integration with a wide range of devices. Its USB-C interface ensures easy connectivity with modern laptops, desktops, and mobile devices, making it a versatile tool for personal and professional use -
User-friendly design
Featuring an external form factor, this fingerprint reader is not only portable but also extremely easy to use. Its Plug-and-Play functionality means you can enjoy enhanced security without the need for complex installations or configurations
- Kensington VeriMark Guard USB-C Fingerprint Key - FIDO2, WebAuthn/CTAP2, & FIDO U2F - Cross Platform fingerprint reader - USB-C - TAA Compliant
- Fingerprint reader
- Interface Type
- USB-C
- TAA Compliant
- 2-year warranty
- Interface Type
- USB-C
- Connections
- 1 x USB - 24 pin USB-C
- U2F Certified
- TAA Compliant
- Limited warranty - 2 years
