With USB ports on laptops becoming a precious commodity, an external hub can be the answer to maintaining optimal productivity. The UH7000C USB 3.0 7-port hub & charger ensures you can connect all your peripheral desktop accessories to your laptop, as well as quickly charge your smartphone or tablet. Leveraging USB 3.0 technology, each of the seven ports can support lightning fast transfer speeds so you can work more efficiently. The ports also double as chargers, ensuring the battery on your favorite devices never runs out. With 4 AMPs available, you can use any of the ports to provide a fast charge for up to two tablets, a tablet and a smartphone, or any other combination of low power devices. Because there are no drivers to download, simply insert the USB cable it into your laptop, plug in the power cord, and you're ready to go.
7 USB 3.0 charge and sync ports
Expand your device's productivity capabilities by plugging your peripheral accessories into any of seven USB 3.0 ports and then watch the battery on your smartphones and/or tablets charge up in the process with the available 4 AMPs of power. -
Lightning fast transfer speeds
Using USB 3.0 technology, the hub supports transfer speeds up to 5 Gbps, which is 10 times faster than USB 2.0. -
Plug & Play operation
Simply insert the USB cable on the hub into your device and it's automatically ready to go with no need for a driver download.
- Kensington UH7000C - hub - 7 ports
- Hub - 7 ports
- Subtype
- USB
- Ports
- 7 x SuperSpeed USB 3.0
- USB 1.1, USB 2.0, USB 3.0
- 10.8 cm x 5.2 cm x 1.7 cm
- 62 g
- Black
- System Requirements
- Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
- Localisation
- Europe
- Hub - 7 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 7 x USB 3.0 Type A
- Power Device
- External power adapter
- Black
- Localisation
- Europe
- OS Required
- 10.8 cm
- 5.2 cm
- 1.7 cm
- 62 g
