Finding the correct ergonomic monitor adjustment is easy, even for desks with a shallow depth, with the SmartFit Space-Saving Single Monitor Arm. Easy, non-permanent installation includes necessary tools. A pre-installed C-clamp faces the front of the desk, making installation much simpler, especially in tight spaces (optional grommet fastener included).
Effortless adjustment
With height, tilt, and swivel adjustments, the Kensington SmartFit Space-Saving Single Monitor Arm offers a customizable viewing experience, allowing users to find the perfect angle and position for their monitor. -
Seamless cable management
Equipped with a Cable Management System (CMS), this monitor arm keeps cables organized and out of sight, promoting a cleaner and more organized workspace. -
Versatile mounting options
Whether it's clamped to the desk edge, mounted through a grommet, or placed on the desktop, this monitor arm offers multiple mounting options to fit various desk setups, ensuring stability and saving valuable desk space.
- Kensington SmartFit Space-Saving Single Monitor Arm mounting kit - Tilt & Swivel - for Monitor - black
- Product Type
- Mounting kit (Tilt & Swivel) - desktop, C-clamp, grommet, desk-mountable
- 18.4 cm x 12.1 cm x 62.2 cm
- Adjustable Height
- 23.8-46.9 cm
- Tilt
- -10° to 10°
- Rotation
- -180° to 180°
- Swivel
- -10° to 10°
- Adjustments
- 7 kg
- Recommended Use
- Monitor
- Recommended Display Size
- Up to 32"
- VESA Mounting Interface
- Max Load Weight
- 8 kg
- Black
- 18.4 cm
- 12.1 cm
- 62.2 cm
- Adjustable Height
- 23.8-46.9 cm
- 7 kg
- Black
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- Monitor
- Placing / Mounting
- Desktop, C-clamp, grommet, desk-mountable
- Cable Management
- Cable Management System (CMS)
- Up to 32"
- Tilt
- -10° to 10°
- Rotation
- -180° to 180°
- Swivel
- -10° to 10°
- Adjustments
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 18.4 cm x 12.1 cm x 62.2 cm / 7 kg
