Kensington Space Saving Monitor Arm Single
Quicklinx: G8TBWS00 Mfr#: K55512WW
£46.85 ex VAT
£56.22 inc VAT
Finding the correct ergonomic monitor adjustment is easy, even for desks with a shallow depth, with the SmartFit Space-Saving Single Monitor Arm. Easy, non-permanent installation includes necessary tools. A pre-installed C-clamp faces the front of the desk, making installation much simpler, especially in tight spaces (optional grommet fastener included).
  • Effortless adjustment
    With height, tilt, and swivel adjustments, the Kensington SmartFit Space-Saving Single Monitor Arm offers a customizable viewing experience, allowing users to find the perfect angle and position for their monitor.
  • Seamless cable management
    Equipped with a Cable Management System (CMS), this monitor arm keeps cables organized and out of sight, promoting a cleaner and more organized workspace.
  • Versatile mounting options
    Whether it's clamped to the desk edge, mounted through a grommet, or placed on the desktop, this monitor arm offers multiple mounting options to fit various desk setups, ensuring stability and saving valuable desk space.
Kensington SmartFit Space-Saving Single Monitor Arm mounting kit - Tilt & Swivel - for Monitor - black
Mounting kit (Tilt & Swivel) - desktop, C-clamp, grommet, desk-mountable
18.4 cm x 12.1 cm x 62.2 cm
Adjustable Height
23.8-46.9 cm
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-10° to 10°
Adjustments
7 kg
Recommended Use
Monitor
Recommended Display Size
Up to 32"
VESA Mounting Interface
Max Load Weight
8 kg
18.4 cm
12.1 cm
62.2 cm
Adjustable Height
23.8-46.9 cm
7 kg
AV Furniture
Mounting kit
Design
Tilt & Swivel
Recommended Use
Monitor
Placing / Mounting
Desktop, C-clamp, grommet, desk-mountable
Cable Management
Up to 32"
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-10° to 10°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
18.4 cm x 12.1 cm x 62.2 cm / 7 kg
Brand: Kensington
