Finding the correct ergonomic monitor adjustment is easy, even for desks with a shallow depth, with the SmartFit Space-Saving Dual Monitor Arm. Easy, non-permanent installation includes necessary tools. A pre-installed C-clamp faces the front of the desk, making installation much simpler, especially in tight spaces (optional grommet fastener included).
Made for shallow spaces
Unique design allows easy monitor adjustment, even in tight spaces. -
Easy-grip adjustment knob and quick-release VESA mounts
Knob allows you to quickly and easily adjust height (239-470mm), tilt and swivel (+/-10°), rotate to landscape or portrait orientation (+/-180°) and lock your monitors in place. Quick-release VESA mounts simplify monitor installation. -
SmartFit system
With SmartFit, finding the right height for maximum comfort is as easy as 1-2-3. Simply match your hand size to the color on the provided chart, set the height to your color and you're done. -
Includes necessary tools and a pre-installed C-clamp that faces the front of the desk, making installation much simpler, especially in tight spaces. C-clamp fits desks up to 85mm thick. -
A single base holds two monitors
Frees up valuable desk space. Allows two monitors to be placed side-by-side and at a proper distance from the viewer. -
Perfect for home or office use
Sleek, sturdy, space-saving design complements a modern aesthetic while keeping your monitors steady and stable. Cable management system eliminates cable clutter for a cleaner desktop.
- Kensington SmartFit Space-Saving Dual Monitor Arm mounting kit - Tilt & Swivel - for 2 monitors - black
- Product Type
- Mounting kit (Tilt & Swivel) - desktop, C-clamp, grommet, desk-mountable
- 73.5 cm x 18 cm x 14.5 cm
- Tilt
- -10° to 10°
- Rotation
- -180° to 180°
- Swivel
- -10° to 10°
- Adjustments
- 6.5 kg
- Recommended Use
- 2 monitors
- Recommended Display Size
- Up to 27"
- VESA Mounting Interface
- Max Load Weight
- 8 kg
- Material
- Plastic, aluminium, steel
- Black
- 2-year warranty
- 73.5 cm
- 18 cm
- 14.5 cm
- 6.5 kg
- Material
- Black
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- 2 monitors
- Placing / Mounting
- Desktop, C-clamp, grommet, desk-mountable
- Cable Management
- Cable Management System (CMS)
- Up to 27"
- Tilt
- -10° to 10°
- Rotation
- -180° to 180°
- Swivel
- -10° to 10°
- Adjustments
- Max Load Weight
- 8 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 73.5 cm x 18 cm x 14.5 cm / 6.5 kg
- Limited warranty - 2 years
