Kensington Space Saving Monitor Arm Dual
Quicklinx: G8TDWS00 Mfr#: K55513WW
36 In Stock
£65.21 ex VAT
£78.25 inc VAT
Finding the correct ergonomic monitor adjustment is easy, even for desks with a shallow depth, with the SmartFit Space-Saving Dual Monitor Arm. Easy, non-permanent installation includes necessary tools. A pre-installed C-clamp faces the front of the desk, making installation much simpler, especially in tight spaces (optional grommet fastener included).
  • Made for shallow spaces
    Unique design allows easy monitor adjustment, even in tight spaces.
  • Easy-grip adjustment knob and quick-release VESA mounts
    Knob allows you to quickly and easily adjust height (239-470mm), tilt and swivel (+/-10°), rotate to landscape or portrait orientation (+/-180°) and lock your monitors in place. Quick-release VESA mounts simplify monitor installation.
  • SmartFit system
    With SmartFit, finding the right height for maximum comfort is as easy as 1-2-3. Simply match your hand size to the color on the provided chart, set the height to your color and you're done.
  • Easy, non-permanent installation
    Includes necessary tools and a pre-installed C-clamp that faces the front of the desk, making installation much simpler, especially in tight spaces. C-clamp fits desks up to 85mm thick.
  • A single base holds two monitors
    Frees up valuable desk space. Allows two monitors to be placed side-by-side and at a proper distance from the viewer.
  • Perfect for home or office use
    Sleek, sturdy, space-saving design complements a modern aesthetic while keeping your monitors steady and stable. Cable management system eliminates cable clutter for a cleaner desktop.
Kensington SmartFit Space-Saving Dual Monitor Arm mounting kit - Tilt & Swivel - for 2 monitors - black
Mounting kit (Tilt & Swivel) - desktop, C-clamp, grommet, desk-mountable
73.5 cm x 18 cm x 14.5 cm
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-10° to 10°
Adjustments
6.5 kg
Recommended Use
2 monitors
Recommended Display Size
Up to 27"
VESA Mounting Interface
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
73.5 cm
18 cm
14.5 cm
6.5 kg
Material
AV Furniture
Mounting kit
Design
Tilt & Swivel
Recommended Use
2 monitors
Placing / Mounting
Desktop, C-clamp, grommet, desk-mountable
Cable Management
Cable Management System (CMS)
Up to 27"
Tilt
-10° to 10°
Rotation
-180° to 180°
Swivel
-10° to 10°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
73.5 cm x 18 cm x 14.5 cm / 6.5 kg
Brand: Kensington
