Kensington SP25 15.6" Classic Backpack
Quicklinx: C3PQWS00 Mfr#: K63207EU
Travel in style with the classic design of the Kensington SP25 backpack. The padded interior pouch protects your laptop computer and the zipped compartments give you easy access to all your essentials when you are on the move.
  • Durable nylon
    Protects and cushions your laptop.
  • Padded shoulder straps
    Designed to ease neck and shoulder strain.
  • Multiple zipped accessories pockets
    Helps you to stay organized on the move.
Kensington SP25 15.4" Classic Backpack - notebook carrying backpack
Notebook carrying backpack
Product Material
Nylon
32 cm x 20 cm x 49 cm
1.3 kg
Notebook Compatibility
15.4"
Padded
Carrying Strap
Shoulder carrying straps
Europe
Product Material
Nylon
32 cm
20 cm
49 cm
1.3 kg
15.4"
Padded
Carrying Strap
Europe
Limited warranty: - lifetime
