Kensington SoleMate Footrest
Quicklinx: C1GVWS00 Mfr#: 56145
Device Type: [N/A]
Type: Footrest
Device Screen Size: [N/A]
Colour: Black/Grey
Hurry, only 2 left in stock!
£35.25 ex VAT
£42.30 inc VAT
Footrests keep legs elevated for improved posture and circulation while you work at a desk and help reduce pressure on the lower back. They are easily adjustable for extra comfort while there is a range of specifications available to suit individual requirements.
  • Ergonomic design
    The Kensington SoleMate Ergonomic Footrest is designed with a 20° tilt and adjustable angle, promoting a more comfortable seating position and reducing strain on the legs and back.
  • Stable support
    Equipped with non-slip feet, this foot-rest ensures stable support, preventing sliding and movement during use, enhancing your overall comfort and focus.
Kensington SoleMate Ergonomic Footrest - foot-rest
Foot-rest
45 cm x 35 cm
2.7 kg
Non-slip feet, adjustable angle, 20° tilt
Foot-rest
45 cm
35 cm
2.7 kg
Limited warranty: - 2 years
Device Type: [N/A]
Type: Footrest
Colour: Black/Grey
Brand: Kensington
