Kensington SoleMate Comfort Footrest
Quicklinx: 56CQWS00 Mfr#: 56153
Type: Footrest
Hurry, only 3 left in stock!
£65.44 ex VAT
£78.52 inc VAT
Footrests keep legs elevated for improved posture and circulation while you work at a desk and help reduce pressure on the lower back. They are easily adjustable for extra comfort, while there is a range of specifications available to suit individual requirements.
  • Luxurious memory foam
    Eases tired and aching feet.
  • Convenient foot pedal
    Adjusts tilt angle from your chair.
  • Tilts up to 20 degrees
    It tilts up to 20 degrees for additional comfort.
  • Elevates legs
    To improve posture and circulation.
  • Helps reduce pressure on lower back
    It also helps to alleviate discomfort from sitting.
Kensington Solemate Comfort Footrest - footrest - grey, black
Footrest
Adjustable Height
Grey, black
2 years
Footrest
Adjustable Height
Tilt Adjustment
Grey, black
Memory foam surface
Warranty
2 years
54.6 cm
35.5 cm
11.7 cm
2.93 kg
Type: Footrest
Brand: Kensington
