Kensington SmartFit SoleMate Pro Ergonomic Foot Rest
Quicklinx: G8QWWS00 Mfr#: K50409EU
£39.31 ex VAT
£47.17 inc VAT
Improve posture, promote healthy circulation and support back and leg comfort with the SmartFit SoleMate Pro ergonomic foot rest. Ergonomically designed to promote wellness and support increased productivity, the SmartFit SoleMate Pro ergonomic foot test incorporates Kensington's patented SmartFit technology to simplify proper fit and allows users to adjust the height and angle for customised comfort. An ideal foot rest for modern home office or hot-desking environments.
  • Ergonomic design
    The Kensington SoleMate Pro features an ergonomic design that supports the natural posture of your feet and legs, reducing strain and enhancing comfort during long periods of use.
  • Customizable comfort
    With SmartFit, adjustable angle, and height settings, the SoleMate Pro allows for a personalized setup, ensuring maximum comfort and productivity.
  • Stable and secure
    Equipped with an anti-slip base and lockable tilt adjustment, this foot-rest stays firmly in place, providing a stable platform for your feet at any angle.
Kensington SoleMate Pro - foot-rest
Foot-rest
Grey
Product Material
High impact polystyrene (HIPS), acrylonitrile butadiene styrene (ABS)
53 cm x 34 cm x 9 cm
2.7 kg
Tilt adjustment, lockable, adjustable height, SmartFit, adjustable angle, anti-slip base
Europe
Foot-rest
Product Material
53 cm
34 cm
9 cm
2.7 kg
Grey
Europe
Limited warranty: - 2 years
Brand: Kensington
