Kensington SmartFit Solemate Plus Foot Rest Black
Quicklinx: FTFWWS00 Mfr#: K52789WW
Accessory Type: Foot Rest
More than 50 In Stock
£45.13 ex VAT
£54.15 inc VAT
Footrests keep legs elevated for improved posture and circulation while you work at a desk and help reduce pressure on the lower back. They are easily adjustable for extra comfort, while there is a range of specifications available to suit individual requirements.
  • Ergonomic design
    The Kensington SmartFit Solemate Plus is designed with your comfort in mind, featuring an adjustable height to align with your personal comfort color using SmartFit System, ensuring a healthier posture and improved circulation while you work.
  • Stable support
    Equipped with non-skid pads, this foot rest provides a stable platform for your feet, preventing slipping and enhancing your overall workstation setup.
Kensington SmartFit Solemate Plus - foot rest
Foot rest
Non-skid pads
Foot rest
Non-skid pads
Brand: Kensington
