Kensington SmartFit Mouse Pad
Quicklinx: BZ7SWS00 Mfr#: K55793EU
£21.82 ex VAT
£26.18 inc VAT
Resting your wrist on a soft, cushioned surface while you click and scroll with your mouse may seem comfortable, but improper positioning can cause discomfort over time. The SmartFit mouse pad not only provides a comfortable gel support, it also allows you to customize and adjust the height of the rest so your wrist is at a neutral angle. An anti-microbial surface resists stains and odors and the non-skid base provides great stability.
  • Gel wrist pad
    The cool, soft cushioning adapts to the natural curves of your wrists for premium comfort and support while you're scrolling and clicking, taking pressure off your joints which is especially important during extended periods of usage.
  • Non-skid base
    Keeps the wrist rest firmly in place, providing important stability so the mouse pad won't slide around while you're trying to be productive.
  • SmartFit system
    Allows you to select your personal height setting so you can work with your mouse for extended periods in optimal comfort.
  • Anti-microbial surface
    Resists stains and odors for a worry-free work area.
Kensington SmartFit mouse pad
Mouse pad
Europe
Mouse pad
Europe
Adjustable height, antimicrobial finish, integrated gel wrist pad, non-skid backing
Brand: Kensington
