Product
Kensington SmartFit Monitor Stand Plus - Grey
Quicklinx: 8M0WWS00 Mfr#: 60089
£38.40 ex VAT
£46.08 inc VAT
Monitor Stand Plus with the SmartFit system adjusts monitor height to your optimal viewing angle to help to reduce eye and neck strain. Expands usable desk space by allowing storage underneath platform.
Kensington SmartFit Plus - stand
Stand - desktop
39.4 cm x 30.5 cm x 14 cm
Adjustments
Recommended Use
LCD display
Recommended Display Size
21"
Max Load Weight
36.3 kg
Grey, black
3 years warranty
39.4 cm
30.5 cm
14 cm
Grey, black
AV Furniture
Stand
Recommended Use
LCD display
Placing / Mounting
Desktop
21"
Adjustments
Max Load Weight
36.3 kg
Dimensions & Weight Details
32.2 cm x 41.3 cm x 5.6 cm / 2.12 kg
Limited warranty - 3 years
Brand: Kensington
Price Range Ex VAT: 0 - 50
