Kensington SmartFit Laptop Riser - Notebook stand - 15.6" -
Quicklinx: CMLCWS00 Mfr#: K52783WW
Device Type: Laptop
Type: Stand
Device Screen Size: 15.6
Colour: Black
12 In Stock
£57.33 ex VAT
£68.79 inc VAT
When you need to lift your laptop up to eye level, theres no better ergonomic solution than the SmartFit Laptop Riser. Kensington has been a leader in ergonomics for more than 20 years and the laptop riser features the SmartFit System, which allows you to find your personal height setting for optimal comfort to reduce neck and back strain while you work. It also utilizes Zero Footprint mounting so you can mount a compatible Kensington universal dock underneath the laptop platform, keeping your desktop less cluttered.
  • SmartFit Customization
    The Kensington SmartFit Laptop Riser incorporates the SmartFit system, allowing for ergonomic adjustment to the individual's optimal comfort level. This feature ensures a personalized setup that can significantly reduce neck and eye strain during long working hours.
  • Efficient Cable Management
    With integrated cable management, this notebook stand keeps your workspace neat and organized, preventing cable clutter. This design not only enhances the aesthetic of your desk but also facilitates a more efficient and focused working environment.
  • Secure and Stable
    Equipped with an anti-skid grip and a Kensington security slot, the Laptop Riser ensures your device remains secure and stable at all times. Whether you're working in a busy office or a public space, you can trust in the added security and stability provided.
  • Adjustable for Comfort
    The adjustable height feature of the Kensington SmartFit Laptop Riser allows users to find the perfect viewing angle, improving posture and comfort during use. This adjustability is crucial for preventing discomfort and potential injury over prolonged periods of use.
  • Zero Footprint Mounting
    This innovative notebook stand offers Zero Footprint Mounting, which allows for the attachment of a compatible Kensington universal dock under the platform. This unique feature maximizes desk space while ensuring a tidy and efficient working area.
Kensington SmartFit Laptop Riser - notebook stand
Notebook stand
Notebook Compatibility
15.6"
Adjustable height, integrated cable management, anti-skid grip, SmartFit, kensington security slot, Zero Footprint Mounting
Notebook stand
15.6"
Weight Limit
3.49 kg
Device Type: Laptop
Type: Stand
Colour: Black
Brand: Kensington
