Kensington SmartFit Ergo Single Monitor Arm Short
Quicklinx: G8T6WS00 Mfr#: K55411WW
29 In Stock
£29.01 ex VAT
£34.81 inc VAT
Finding the correct ergonomic monitor height is easy, thanks to the sturdy, stable SmartFit Ergo Single Monitor Arm. Clear valuable desk space while improving ergonomics. Wide adjustment range delivers ±90° swivel, ±180° rotation (for landscape or portrait orientation) and ±45° monitor tilt adjustment. Sturdy, metal C-clamp and grommet fastener are easy to install and won't damage or mark the desk or table. Compatible with displays up to 34" and 8kg/17.6lbs.
  • Effortless adjustment
    The Kensington SmartFit Ergo Single Monitor Arm offers an adjustable arm design, allowing for easy positioning of your monitor to the perfect viewing angle. With tilt ranges from -45° to 45°, swivel from -90° to 90°, and rotation from -180° to 180°, it ensures optimal ergonomics for reduced strain during long work sessions.
  • Versatile mounting options
    Designed to fit a variety of desk setups, this mounting kit supports C-clamp and grommet installation on desktops, making it a flexible solution for any workspace. Its compatibility with desks ensures a secure and stable monitor setup.
  • Seamless cable management
    Featuring a Cable Management System (CMS), the Kensington SmartFit Ergo Single Monitor Arm keeps your workspace tidy by neatly routing cables away from the desktop. This system enhances the overall aesthetics and functionality of your work area.
Kensington SmartFit Ergo Single Monitor Arm mounting kit - adjustable arm - for Monitor - black
Mounting kit (adjustable arm) - desktop, C-clamp, grommet, desk-mountable
54.8 cm x 11.4 cm x 14.8 cm
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
2.78 kg
Recommended Use
Monitor
Recommended Display Size
Up to 34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
54.8 cm
11.4 cm
14.8 cm
2.78 kg
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desktop, C-clamp, grommet, desk-mountable
Cable Management
Up to 34"
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
Max Load Weight
8 kg
Dimensions & Weight Details
45.6 cm x 13.5 cm x 16.3 cm
Brand: Kensington
