Kensington SmartFit Ergo Single Monitor Arm - Long
Quicklinx: G8T3WS00 Mfr#: K55408WW
38 In Stock
£37.31 ex VAT
£44.77 inc VAT
Finding the correct ergonomic monitor height and adjusting its distance is easy, thanks to the sturdy, stable SmartFit Ergo Single Extended Monitor Arm. Clear valuable desk space while improving ergonomics. Wide adjustment range delivers ±90° swivel, ±180° rotation (for landscape or portrait), ±45° monitor tilt adjustment and up to 399mm/15.7" arm extension. Sturdy metal C-clamp and grommet fastener are easy to install and won't damage or mark the desk or table. Compatible with displays up to 34" and 8kg/17.6lbs.
  • SmartFit system
    With SmartFit, finding the right height for maximum comfort is as easy as 1, 2, 3. Simply match your hand size to the color on the provided chart, set the height to your color and you're done.
  • Wide adjustment range
    Delivers ±90° swivel, ±180° rotation (for landscape or portrait orientation) and ±45° monitor tilt adjustment for ergonomic comfort.
  • Extendable arm
    Lets you easily adjust the monitor's distance.
  • C-clamp and grommet fastener included
    Durable steel and aluminum construction, requires less desk space to attach, is easy to install and won't damage or mark desk or table.
  • Cable management system
    Eliminates cable clutter for a cleaner desktop.
Kensington SmartFit Ergo Single Extended Monitor Arm mounting kit - adjustable arm - for Monitor - black
Mounting kit (adjustable arm) - desktop, C-clamp, grommet, desk-mountable
54.8 cm x 11.4 cm x 52 cm
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
3.32 kg
Recommended Use
Monitor
Recommended Display Size
Up to 34"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Powder-coated steel
54.8 cm
11.4 cm
52 cm
3.32 kg
Material
Powder-coated steel
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
Monitor
Placing / Mounting
Desktop, C-clamp, grommet, desk-mountable
Cable Management
Cable Management System (CMS)
Up to 34"
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
Max Load Weight
8 kg
Dimensions & Weight Details
45.6 cm x 13.5 cm x 23.3 cm / 3.85 kg
Brand: Kensington
