Kensington SmartFit Ergo Dual Monitor Arm
Quicklinx: G8T4WS00 Mfr#: K55409WW
More than 50 In Stock
£46.99 ex VAT
£56.38 inc VAT
Finding the correct ergonomic height for your monitors and adjusting their distance is easy, thanks to the sturdy, stable SmartFit Ergo Dual Extended Monitor Arm. Clear valuable desk space while improving ergonomics. Wide adjustment range delivers ±90° swivel, ±180° rotation (for landscape or portrait), ±45° monitor tilt adjustment and up to 399mm/15.7" arm extension. Sturdy metal C-clamp and grommet fastener are easy to install and won't damage or mark the desk or table. Each arm is compatible with displays up to 32" and 8kg/17.6lbs.
  • Versatile placement options
    The Kensington SmartFit Ergo Dual Extended Monitor Arm offers a variety of placement options including C-clamp, desk-mountable, desktop, and grommet solutions, ensuring it can be securely and conveniently attached to any workspace setup.
  • Comprehensive adjustability
    Featuring width adjustments, a rotation range of -180° to 180°, swivel from -90° to 90°, and tilt capabilities of -45° to 45°, this mounting kit allows for optimal viewing angles and ergonomic positioning of two monitors, enhancing productivity and comfort.
  • Robust build and compatibility
    Constructed from durable metal and designed to support two monitors up to 32 inches or 81.3 cm in size and 8 kg in weight, the arm is compatible with flat panel mount interfaces of 100 x 100 mm and 75 x 75 mm, accommodating a wide range of monitor models.
Kensington SmartFit Ergo Dual Extended Monitor Arm mounting kit - adjustable arm - for 2 monitors - black
Mounting kit (adjustable arm) - desktop, C-clamp, grommet, desk-mountable
91.3 cm x 14.8 cm x 54.8 cm
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
4.3 kg
Recommended Use
2 monitors
Recommended Display Size
Up to 32"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Metal
91.3 cm
14.8 cm
54.8 cm
4.3 kg
Material
Metal
AV Furniture
Mounting kit
Design
Adjustable arm
Recommended Use
2 monitors
Placing / Mounting
Desktop, C-clamp, grommet, desk-mountable
Cable Management
Cable Management System (CMS)
Up to 32"
Tilt
-45° to 45°
Rotation
-180° to 180°
Swivel
-90° to 90°
Adjustments
Max Load Weight
8 kg
Dimensions & Weight Details
45.6 cm x 13.5 cm x 23.3 cm / 4.85 kg
Brand: Kensington
