Kensington SmartFit Easy Riser Go Large
Quicklinx: G8RTWS00 Mfr#: K50420EU
£19.42 ex VAT
£23.30 inc VAT
Combine the ergonomic benefits of raising your screen height with the technological benefits of increased air circulation for your laptop with the Kensington SmartFit Easy Riser Go Adjustable Ergonomic Laptop Riser and Cooling Stand. The sleek 2-in-1 design is height and angle adjustable to improve posture, promote proper eye alignment and support neck and shoulder comfort while keeping the laptop's internal components cool. Anti-slip foot pads prevent the stand from sliding forward, padded inserts provide a secure fit for your device, and the slim foldable design is made for travel. Use with an external keyboard and mouse (sold separately). Supports 17" standard and gaming laptops.
  • Ergonomic design
    The Easy Riser Go Laptop Cooling Stand by Kensington is meticulously designed with adjustable height and angle options, offering 8 positions to ensure an ergonomic setup. This flexibility helps reduce neck and eye strain, making long hours of work or study more comfortable.
  • Enhanced stability
    Equipped with anti-slip feet, this notebook stand ensures your device remains stable during use. Whether you're typing away or engaging in intensive design work, the stand's firm grip prevents any unwanted movement, ensuring your laptop stays securely in place.
  • Optimal compatibility
    Designed to support notebooks up to 17 inches (43.2 cm), the Easy Riser Go accommodates a wide range of laptop sizes. This versatility ensures that most users can benefit from its ergonomic and cooling features, making it a valuable accessory for any notebook owner.
Kensington Easy Riser Go Laptop Cooling Stand - notebook stand
Notebook stand
Notebook Compatibility
17"
SmartFit, anti-slip feet, adjustable angle (8 positions)
Notebook stand
17"
Brand: Kensington
