Kensington SmartFit Dual Monitor Arm
Quicklinx: CMLGWS00 Mfr#: K60273WW
£160.89 ex VAT
£193.06 inc VAT
With more than 20 years of expertise creating professional-level ergonomic solutions, Kensington has created the SmartFit Dual Monitor Arm Mount. It allows you to add a second display to your desktop, which studies have shown can have a significant impact on daily productivity. With two fully adjustable arms that hold up to 24 monitors, you can use our patented SmartFit system to find your optimal height setting to reduce neck, back and vision strain. It assembles in minutes, letting you quickly get back to whats important.
Kensington SmartFit Dual Monitor Arm Mount - mounting kit
Mounting kit - desktop
Mounting Components
Desk clamp mount, 2 monitor arms
Adjustments
Height, pan, tilt, lift
Recommended Use
2 LCD displays
Dark grey
Dark grey
AV Furniture
Mounting kit
Mounting Components
Recommended Use
2 LCD displays
Placing / Mounting
Desktop
Cable Management
Integrated cable management
Adjustments
Adjustable Feet
Brand: Kensington
Price Range Ex VAT: 150 - 300
