Kensington SmartFit Conform Back Rest
Reduced Price - Whilst Stocks Last!
Quicklinx: BZ7VWS00 Mfr#: K60412WW
The SmartFit Conform Back Rest takes sitting comfort to a new level, with patented back support technology that works in nearly any type of chair. The SmartFit System allows you to customize the height of the back rest to your personal comfort color for maximum support for your spine and lumbar. Ventilated back panels conform to your body type through four independent springs that articulate when you shift your posture. And because the panels are ventilated, it dissipates heat to keep your back cool and dry throughout the workday.
  • Height adjustable
    Slide the base up or down to your comfort color to set your back rest at the ideal height, providing the maximum comfort and support for your spine and lumbar while sitting in a chair.
  • Four independent springs
    Conform to your body type and articulate with any subtle movements in your posture so you always have great support to leave your back muscles more relaxed.
  • Ventilated supports
    Dissipates heat when you sit in the chair for long periods of time, keeping your back cool and dry for a more comfortable sitting experience.
  • Removable, washable fabric
    Simply slide the covers off the supports and place them in a washing machine in case of accidental drink or food spill, or when you just want to freshen up the fabric.
Kensington SmartFit Conform Back Rest - backrest
Backrest
Product Material
Fabric
13.5 cm x 43 cm x 41 cm
1.81 kg
Adjustable height
2 years warranty
Backrest
Product Material
Fabric
13.5 cm
43 cm
41 cm
1.81 kg
Adjustable height
