This precision laser mouse travels well and is ready when you are. The Kensington SlimBlade Wireless Laser Mouse offers a laser sensor for precise control on more surfaces. A storable nano receiver offers wireless freedom and is always ready to work. Plus the thin profile, ultra portable design makes mobility easy.
Effortless compatibility
Designed to seamlessly integrate with PC systems, this mouse ensures a smooth and hassle-free user experience, making it an ideal choice for both work and play. -
Wireless freedom
With its advanced 2.4 GHz connectivity technology, the Kensington SlimBlade mouse offers the freedom to move without the constraint of wires, enhancing your productivity and comfort. -
Precision tracking
Equipped with laser movement detection technology, this mouse delivers precise and accurate cursor control, allowing for an optimized browsing and editing experience.
- Kensington SlimBlade with Nano Receiver - mouse - 2.4 GHz
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Localisation
- Europe
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Scrolling wheel (4-way), battery indicator, on/off power switch
- Microsoft Certification
- Compatible with Windows 7
- Mouse
- Wireless Receiver
- Localisation
- Europe
Input Device
- Wireless
- Interface
- 2.4 GHz
- Laser
- 1 x USB - 4 pin USB Type A
