Kensington Slim Resettable NanoSaver Combination Laptop Lock
Quicklinx: G8QGWS00 Mfr#: K60603WW
Device Type: Laptop
Type: Security
Device Screen Size: [N/A]
Colour: Black, Silver
£34.89 ex VAT
£41.86 inc VAT
With today's slim laptops featuring the Nano security slot, a typical cable lock head may fit. However, as the laptop itself is so thin, once the lock is attached the laptop will not lie flat since the thickness of the lock is greater than the laptop. The Slim NanoSaver Combination Laptop Lock is the strongest keyless locking solution that allows ultra-thin and 2-in-1 laptops with nano lock slots to lie flat and stable.
  • Advanced stability
    Slim Nano lock head won't raise your device off its surface.
  • Tough lock head and cable
    Verified and tested for advanced standards in torque/pull, foreign implements, lock lifecycle, corrosion and other environmental conditions. Carbon steel cable resists cutting attempts and anchors to desks, tables and other attachment points.
  • Unique lock engagement
    Expanding side "hooks" grab the internal sides of the Nano lock slot, creating a strong connection between the device frame and the lock to resist and deter theft.
  • Pivot-and-rotate cable head
    Allows for easy and flexible connection and movement.
  • Resettable 4-wheel number code with Register and Retrieve
    10.000 possible combinations, selectable by the user. Code registration allows for quick, easy and secure lookup if the combination is ever lost or forgotten.
Kensington Slim NanoSaver Combination Laptop Lock - security cable lock
Security cable lock
Product Material
Carbon steel
3.16 cm x 180 cm x 1.1 cm
Length
1.8 m
200 g
4 digit code, cut-resistant, rotate adjustment, resettable function, 10000 user-settable combinations
5-year warranty
Security cable lock
Product Material
Carbon steel
3.16 cm
180 cm
1.1 cm
Length
1.8 m
Diameter
0.5 cm
200 g
15.2 cm x 21.2 cm x 2.5 cm / 209 g
Security Cable Lock
Intended For
Notebook
Lock Type
Nano
Lock Method
Combination
Limited warranty: - 5 years
Device Type: Laptop
Type: Security
Colour: Black
Colour: Silver
Brand: Kensington
