Kensington Slim Resettable Combination Laptop Lock for Standard Security Slot
Quicklinx: G8QFWS00 Mfr#: K60600WW
£32.87 ex VAT
£39.44 inc VAT
With today's slim laptops, a typical cable lock head might fit, but the laptop itself is so thin that once the lock is attached, it doesn't allow the laptop to lie flat because the thickness of the lock is greater than the laptop, unevenly raising it off its surface. The Slim Combination Laptop Lock is the strongest keyless locking solution that allows ultra-thin and 2-in-1 laptops with standard lock slots to lie flat and stable.
  • Advanced stability
    Allows ultra-thin and 2-in-1 laptops to lie flat and stable. Slim lock head won't raise your device off its surface.
  • Tough lock head and cable
    Verified and tested for advanced standards in torque/pull, foreign implements, lock lifecycle, corrosion and other environmental conditions. Carbon steel cable resists cutting attempts and anchors to desks, tables and other attachment points.
  • Unique lock engagement
    Expanding side "hooks" grab the internal sides of the lock slot, creating a strong connection between the device frame and the lock to resist and deter theft.
  • Pivot-and-rotate cable head
    Allows for easy and flexible connection and movement.
  • Resettable 4-wheel number code with Register and Retrieve
    10.000 possible combinations, selectable by the user. Code registration allows for quick, easy and secure lookup if the combination is ever lost or forgotten.
Kensington Slim Combination Laptop Lock - security cable lock
Security cable lock
Product Material
Carbon steel
3.16 cm x 180 cm x 1.1 cm
Length
1.8 m
200 g
Cut-resistant, rotate adjustment, 10000 user-settable combinations, 4 digit code, resettable function
5-year warranty
Security cable lock
Product Material
Carbon steel
3.16 cm
180 cm
1.1 cm
Length
1.8 m
Diameter
0.5 cm
200 g
15.2 cm x 21.2 cm x 2.5 cm / 209 g
Security Cable Lock
Intended For
Notebook
Lock Type
T-Bar
Lock Method
Combination
Limited warranty: - 5 years
