The MicroSaver lock head features the patented T-bar locking mechanism. The T-bar provides a tight fit with the Kensington Security Slot. A rubber bumper ensures a snug fit between the lock and the security slot and protects your hardware. A further deterrent is the tamper evident feature. When a Kensington MicroSaver lock is tampered with, it locks itself down and can even trap foreign keys.
All Kensington locks are built to exacting engineering standards. This lock is rated as Safe Pro, a rating awarded to Kensington Security Locks that are tested under stringent test conditions by third party testing agencies for their ability to withstand attacks.
We provide two keys with each standard lock. Each key is stamped with a unique code. Register your code online and well be able to send you a replacement key.
Our business is protecting yours
Kensington locks are made with high-carbon steel cables and tested under rigorous real-world conditions to resist lock-picking, corro.
Strong lock head
Tested against the most rigorous and thorough standards in the industry, the lock is tamper-resistant and will durably perform time after time. -
Hidden Pin technology
Ensures the tubular lock cannot be picked by tampering with the circular area where the key is inserted. -
T-Bar Locking Technology
The trusted industry standard for more than 20 years and compatible with the Kensington Security Slot found in most laptops. The rotating bar securely attaches to the internal wall of the device for a premium level of security. -
Cut-resistant cable
Made of engineered carbon steel and sheathed in protective plastic, it offers the same level of cut resistance and theft resistance of much thicker cables while providing easier mobility.
- Kensington MicroSaver - security cable lock
- Product Type
- Security cable lock
- Package Content
- Security cable
- 0.53 cm x 180 cm x 0.53 cm
- 250 g
- Key lock, T- bar lock
- Package Type
- Retail
- Limited lifetime warranty
- Product Type
- Package Content
- Security cable
- 0.53 cm
- 180 cm
- 0.53 cm
- 250 g
- Package Type
- Retail
- Limited warranty: - lifetime
