Kensington Sit Stand Workstation Dual Arm
Quicklinx: CRK5WS00 Mfr#: K55759WW
£51.40 ex VAT
£61.68 inc VAT
Please Note: This is only the Dual Monitor Arm, not the full Workstation. This needs to be purchased with KW55792WW - Quicklinx BWGP
Take productivity to a professional level by adding a dual monitor arm to your SmartFit Sit/Stand Workstation. Studies have shown using two monitors can have a dramatic effect on workflow. With dual monitors on your workstation, not only are you getting the ergonomic and health benefits of standing while you work, youre also getting a lot more work done. Our patented SmartFit System lets you find your personal comfort color to set the monitors at the ideal viewing height, plus the arm installs quickly to your Sit/Stand workstation and is VESA-compatible for monitor screens up to 24 inches.
Kensington mounting component - for 2 monitors - black
Mounting component
Mounting Components
Dual arm
Recommended Use
2 monitors
Recommended Display Size
Up to 24"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
10.2 kg
AV Furniture
Mounting component
Mounting Components
Dual arm
Recommended Use
2 monitors
Up to 24"
Max Load Weight
10.2 kg
Brand: Kensington
