Kensington SD6000 Surface Go Dock
Quicklinx: G7C4WS00 Mfr#: K38700EU
At last, the perfect Surface Go dock for maximum productivity, creativity and security has arrived. The game-changing SD6000 Surface Go Docking Station is the first all-in-one Surface Go docking solution exclusively designed for Microsoft Surface to provide the productivity benefits of a docking station, the creativity benefits of studio mode designing and surface pen stowing, and the security benefits of a flexible mounting solution. It is the ideal choice for offices with security protocols, point-of-sale locations, check-in counters, mobile carts, kiosks, education environments and conference rooms. Connect to the perfect Surface Go companion – one dock for more productivity, more creativity, and more security.
  • Designed exclusively for Surface Go
    Built on Microsoft's proprietary Surface Connect technology, users can connect with confidence for a seamless dock and charge experience that looks great and functions perfectly.
  • Productive desktop ports
    A powerful plug and play experience extends productivity via four USB-A 3.1 ports (5 V/0.9 A), one USB-C 3.1 port for data synchronization (5 V/3 A), a 3.5-mm combo audio jack and a Gigabit Ethernet port.
  • Versatile external display options
    Easily connect to external monitors, TVs or projectors via HDMI or DisplayPort++ (single 4K @ 60 Hz; dual 4K @ 30 Hz).
  • Protective engineering
    Extend the life of your investment with thoughtful design elements, including enhanced air flow, heat dissipation and an integrated cradle pin designed to protect the Surface Connect cable.
Kensington SD6000 - docking station - Surface Connect - HDMI, DP - 1GbE
Docking station
Docking Interface
Surface Connect
Video Interfaces
HDMI, DP
39 cm x 32.5 cm x 16 cm
4.38 kg
Silver
Europe
Gigabit Ethernet
Power adapter 90 Watt Power Provided
3-year warranty
Microsoft Surface Go
Docking station
39 cm
32.5 cm
16 cm
4.38 kg
Enclosure Colour
Silver
Europe
Video
Max Resolution Details
3840 x 2160 - 60 Hz
1 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.1 - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 4 x USB 3.1 - 9 pin USB Type A
Security lock slot (cable lock sold separately), integrated stylus holder, dual monitor support, 4K Ultra HD, DockWorks
Security Slot Type
Kensington security slot
Plug and Play, VCCI, CCC, EMC, IC, FCC, RoHS, RCM, DisplayPort 1.2++
Power adapter
Power Provided
90 Watt
Limited warranty - 3 years
