At last, the perfect Surface Go dock for maximum productivity, creativity and security has arrived. The game-changing SD6000 Surface Go Docking Station is the first all-in-one Surface Go docking solution exclusively designed for Microsoft Surface to provide the productivity benefits of a docking station, the creativity benefits of studio mode designing and surface pen stowing, and the security benefits of a flexible mounting solution. It is the ideal choice for offices with security protocols, point-of-sale locations, check-in counters, mobile carts, kiosks, education environments and conference rooms. Connect to the perfect Surface Go companion – one dock for more productivity, more creativity, and more security.
Designed exclusively for Surface Go
Built on Microsoft's proprietary Surface Connect technology, users can connect with confidence for a seamless dock and charge experience that looks great and functions perfectly. -
Productive desktop ports
A powerful plug and play experience extends productivity via four USB-A 3.1 ports (5 V/0.9 A), one USB-C 3.1 port for data synchronization (5 V/3 A), a 3.5-mm combo audio jack and a Gigabit Ethernet port. -
Versatile external display options
Easily connect to external monitors, TVs or projectors via HDMI or DisplayPort++ (single 4K @ 60 Hz; dual 4K @ 30 Hz). -
Protective engineering
Extend the life of your investment with thoughtful design elements, including enhanced air flow, heat dissipation and an integrated cradle pin designed to protect the Surface Connect cable.
- Kensington SD6000 - docking station - Surface Connect - HDMI, DP - 1GbE
- Product Type
- Docking station
- Docking Interface
- Surface Connect
- Video Interfaces
- HDMI, DP
- 39 cm x 32.5 cm x 16 cm
- 4.38 kg
- Silver
- Localisation
- Europe
- Networking
- Gigabit Ethernet
- Power
- Power adapter 90 Watt Power Provided
- 3-year warranty
- Designed For
- Microsoft Surface Go
- Product Type
- Docking station
- 39 cm
- 32.5 cm
- 16 cm
- 4.38 kg
- Enclosure Colour
- Silver
- Localisation
- Europe
Video
- Max Resolution Details
- 3840 x 2160 - 60 Hz
- Data Link Protocol
- 1 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x USB-C 3.1 - 24 pin USB-C , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x headphone/microphone combo jack - mini-phone 3.5 mm , 4 x USB 3.1 - 9 pin USB Type A
- Security lock slot (cable lock sold separately), integrated stylus holder, dual monitor support, 4K Ultra HD, DockWorks
- Security Slot Type
- Kensington security slot
- Plug and Play, VCCI, CCC, EMC, IC, FCC, RoHS, RCM, DisplayPort 1.2++
- Power Device
- Power adapter
- Power Provided
- 90 Watt
- Limited warranty - 3 years
- Designed For
